Salta al contenuto principale
HP Compaq Presario V5303NR Disk Drive Replacement
Cosa ti serve
  1. HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: passo 1, immagine 1 di 3 HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: passo 1, immagine 2 di 3 HP Compaq Presario V5303NR Disk Drive Replacement, Disk Drive: passo 1, immagine 3 di 3
    • Turn the laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Remove the battery from its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR Disk Drive Replacement: passo 2, immagine 1 di 2 HP Compaq Presario V5303NR Disk Drive Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the 3 5mm #0 screws highlighted in the picture.
    • Use the Phillips #0 screwdriver to remove the 2 4mm #0 screws highlighted in the picture.
    • Use the Phippips #0 screwdriver to remove the 10 5mm #0 screws highlighted in the picture.
    • Keep the different types of screws separate from one another. They will only fit into holes created for screws of their size, and thus cannot fit into other screw holes.
  3. HP Compaq Presario V5303NR Disk Drive Replacement: passo 3, immagine 1 di 2 HP Compaq Presario V5303NR Disk Drive Replacement: passo 3, immagine 2 di 2
    • Remove the laptops bottom panel.
  4. HP Compaq Presario V5303NR Disk Drive Replacement: passo 4, immagine 1 di 1
    • Gently remove the disk drive from its socket.
Conclusione
Christopher M Paiva
Membro da: 03/19/18
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 159
