Salta al contenuto principale
HP Compaq Presario CQ56-110US Keyboard Replacement
Cosa ti serve
Panoramica Video
  1. HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP Compaq Presario CQ56-110US Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure that the laptop is completely powered off, then flip it over to identify the battery latch located towards the bottom of the back panel.
    • Push the latch to the unlocked position.
  2. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 2, immagine 1 di 1
    • Gently take out the battery.
  3. HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 HP Compaq Presario CQ56-110US Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • On the back panel of the laptop are two screws which have a keyboard symbol next to them.
    • Using a Phillips screwdriver with a PH0 bit, remove both the 7mm and 5.5mm screws.
  4. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 4, immagine 1 di 2 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 4, immagine 2 di 2
    • From left to right, unscrew the 5.5mm screw, the 7mm screw, and the 5.5mm screw located in the battery panel with the screwdriver.
  5. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 5, immagine 1 di 2 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 5, immagine 2 di 2
    • Remove the RAM panel by unscrewing the three screws with the PH0 Screwdriver Bit.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool
    • Remove the RAM panel using a plastic opening tool.
  6. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 6, immagine 1 di 1
    • Inside the RAM panel, use the screwdriver to remove the 5mm screw pictured.
  7. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 7, immagine 1 di 1
    • Flip the laptop back over and lift the lid to expose the keyboard.
  8. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 8, immagine 1 di 2 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 8, immagine 2 di 2
    • Use a plastic opening tool to pry up the keyboard.
  9. HP Compaq Presario CQ56-110US Keyboard Replacement: passo 9, immagine 1 di 2 HP Compaq Presario CQ56-110US Keyboard Replacement: passo 9, immagine 2 di 2
    • Once the keyboard is lifted, disconnect the band.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 8-4, Eyestone Spring 2017 Membro di USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 Membri
5 Guide realizzate
Un commento
Difficulty HARD ? oh please… please change to EASY… just some screws?
Assembler Computer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,513
