Salta al contenuto principale
HP Compaq Presario CQ56-110US CD Drive Replacement
Cosa ti serve
  1. HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: passo 1, immagine 1 di 2 HP Compaq Presario CQ56-110US CD Drive Replacement, CD Drive: passo 1, immagine 2 di 2
    • Loosen the two indicated screws on the panel using a Phillips screwdriver with a PH1 head size.
    • The screws do not come free from the panel. They only need to be loosened enough so that the panel can be lifted/pried using a plastic opening tool.
  2. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 2, immagine 1 di 1
    • Use the screwdriver to unscrew the four 5mm screws holding down the hard drive.
  3. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 3, immagine 1 di 2 HP Compaq Presario CQ56-110US CD Drive Replacement: passo 3, immagine 2 di 2
    • Use plastic opening tools to lift up the hard drive. Set aside the hard drive without disconnecting the wire.
  4. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 4, immagine 1 di 1
    • Use a Phillips screwdriver with a PH0 head type to unscrew the indicated 5.5mm screw.
  5. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 5, immagine 1 di 1
    • Use plastic opening tools to pry open the CD Drive.
  6. HP Compaq Presario CQ56-110US CD Drive Replacement: passo 6, immagine 1 di 1
    • Use your hands to pull the CD drive out and remove it from the laptop.
Conclusione
USF Tampa, Team 8-4, Eyestone Spring 2017 Membro di USF Tampa, Team 8-4, Eyestone Spring 2017
USFT-EYESTONE-S17S8G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 823
