Salta al contenuto principale
HP Compaq 6710b Power Button Panel Replacement
Cosa ti serve
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: passo 1, immagine 1 di 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: passo 1, immagine 2 di 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: passo 1, immagine 3 di 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: passo 2, immagine 1 di 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: passo 3, immagine 1 di 2 HP Compaq 6710b Power Button Panel Replacement: passo 3, immagine 2 di 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: passo 4, immagine 1 di 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: passo 5, immagine 1 di 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: passo 6, immagine 1 di 3 HP Compaq 6710b Power Button Panel Replacement: passo 6, immagine 2 di 3 HP Compaq 6710b Power Button Panel Replacement: passo 6, immagine 3 di 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Conclusione
Altre 4 persone hanno completato questa guida.
Khulan Orgil
Membro da: 04/14/15
1.171 Reputazione
6 Guide realizzate
Cal Poly, Team 4-2, Maness Spring 2015 Membro di Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,574
