Salta al contenuto principale
HP Compaq 6510b Hard Drive Replacement
Cosa ti serve
  1. HP Compaq 6510b Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Compaq 6510b Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: passo 2, immagine 2 di 3 HP Compaq 6510b Hard Drive Replacement, Hard Drive: passo 2, immagine 3 di 3
    • Flip the laptop over and locate the sign that says HP 3D DriveGuard.
    • Remove the two 5mm JIS #1 screws with your screwdriver.
    • Carefully lift up the cover.
    • Carefully lift up the hard drive from the back and pull it out.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 887
