Salta al contenuto principale
HP Compaq 2510p RAM Replacement
Cosa ti serve
  1. HP Compaq 2510p RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: passo 2, immagine 1 di 1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: passo 3, immagine 1 di 1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: passo 4, immagine 1 di 1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: passo 5, immagine 1 di 1
    • Remove the old RAM by lifting it upwards, then pulling.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 774
