Salta al contenuto principale
HP Chromebook x360 14c-ca0053 Screen Replacement
Cosa ti serve
  1. HP Chromebook x360 14c-ca0053 Screen Replacement, Lower Case: passo 1, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement, Lower Case: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
    • Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
  2. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 2, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 3.5 mm screws.
  3. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 3, immagine 1 di 3 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 3, immagine 2 di 3 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 3, immagine 3 di 3
    • Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
  4. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 4, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
  5. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 5, immagine 1 di 3 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 5, immagine 2 di 3 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 5, immagine 3 di 3
    • Insert an opening pick between lower case and chassis.
    • Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
  6. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 6, immagine 1 di 1
    • Lift the lower case up and off.
  7. HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: passo 7, immagine 1 di 3 HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: passo 7, immagine 2 di 3 HP Chromebook x360 14c-ca0053 Screen Replacement, Battery: passo 7, immagine 3 di 3
    Compra
    • Open the tweezers wide enough to fit on each side of motherboard battery connection.
    • Pull the connector directly out of its socket.
  8. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 8, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
    • These screws are labeled 1-5.
  9. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 9, immagine 1 di 1
    • Lift the battery up and out.
    • Be careful as to not puncture or damage the battery.
  10. HP Chromebook x360 14c-ca0053 Screen Replacement, Screen: passo 10, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement, Screen: passo 10, immagine 2 di 2
    • Use the opening pick to create a small gap between the back panel of the screen and the display screen.
    • If it is difficult to insert the opening pick between the screen and back panel, use the metal spudger instead.
  11. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 11, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 11, immagine 2 di 2
    Compra
    • Use tweezers to locate the black tape between the back panel and the display screen.
    • Pull the adhesive through the gap on each side of the screen until it comes loose.
    • Replace the adhesive during reassembly.
  12. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 12, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 12, immagine 2 di 2
    • Use tweezers to peel back the square-shaped silver tape on the top side of the device.
  13. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 13, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 13, immagine 2 di 2
    • Use tweezers to lift up the black metal wire covering the connector.
    • Gently pull the display connector out from the device.
  14. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 14, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 14, immagine 2 di 2
    • Use the tweezers to lift the gray square with the black wire from the motherboard.
  15. HP Chromebook x360 14c-ca0053 Screen Replacement: passo 15, immagine 1 di 2 HP Chromebook x360 14c-ca0053 Screen Replacement: passo 15, immagine 2 di 2
    • Remove the screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 34
Tutti i Tempi: 289
