Salta al contenuto principale
HP Chromebook x360 11-ae010nr Display Replacement
Cosa ti serve
  1. HP Chromebook x360 11-ae010nr Display Replacement, Keyboard: passo 1, immagine 1 di 2 HP Chromebook x360 11-ae010nr Display Replacement, Keyboard: passo 1, immagine 2 di 2
    • Flip the device upside down so that the screws are visible.
    • Loosen two captive Phillips #1 screws from the center of the device.
    • Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
    • Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
  2. HP Chromebook x360 11-ae010nr Display Replacement: passo 2, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 2, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 2, immagine 3 di 3
    • Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
    • Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
    • Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
  3. HP Chromebook x360 11-ae010nr Display Replacement: passo 3, immagine 1 di 2 HP Chromebook x360 11-ae010nr Display Replacement: passo 3, immagine 2 di 2
    • Separate the keyboard assembly and the case.
    • Two cables connect the keyboard to the device, so take caution to not damage these cables.
    • Flip the black plastic tab where the wider cable meets the main board using the tip of a spudger or a fingernail.
    • Remove the cable with curved needle nose pliers or your fingers.
  4. HP Chromebook x360 11-ae010nr Display Replacement: passo 4, immagine 1 di 2 HP Chromebook x360 11-ae010nr Display Replacement: passo 4, immagine 2 di 2
    • Flip the white plastic tab where the thinner cable meets the main board using the tip of a spudger or a fingernail.
    • Separate the keyboard from the laptop.
  5. HP Chromebook x360 11-ae010nr Display Replacement, Display: passo 5, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement, Display: passo 5, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement, Display: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to gently but firmly pull each of the black cables out from their sockets.
  6. HP Chromebook x360 11-ae010nr Display Replacement: passo 6, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 6, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 6, immagine 3 di 3
    • Use a pair of tweezers to partially peel and hold both plastic strips away from the golden connector cable.
    • Use an opening tool to pull the golden cable out from its socket.
  7. HP Chromebook x360 11-ae010nr Display Replacement: passo 7, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 7, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 7, immagine 3 di 3
    • Use a pair of tweezers to gently pull back and hold the plastic strip.
    • Pull the black cable out from its socket.
  8. HP Chromebook x360 11-ae010nr Display Replacement: passo 8, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 8, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 8, immagine 3 di 3
    • Use a pair of tweezers to flip up the white clip.
    • Gently remove the white and blue ribbon cable from its socket.
  9. HP Chromebook x360 11-ae010nr Display Replacement: passo 9, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 9, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 9, immagine 3 di 3
    • Remove the two 6 mm Phillips #0 screws from the metal bracket on the left side of the device.
    • Remove the two 6 mm Phillips #0 screws from the metal bracket on the right side of the device.
  10. HP Chromebook x360 11-ae010nr Display Replacement: passo 10, immagine 1 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 10, immagine 2 di 3 HP Chromebook x360 11-ae010nr Display Replacement: passo 10, immagine 3 di 3
    • Carefully pull the display towards you while keeping the both brackets parallel to the body of the device.
    • Keep wires out of the way as they can be easily damaged when removing the display.
Conclusione
jonas wojtas
Membro da: 10/25/19
216 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,671
