Introduzione
This guide demonstrates the replacement of the Chromebook's speakers. This will require the removal of the front keyboard plate and accessing the laptop's internals. You will need to remove and keep track of thirteen 6mm screws in total.
Cosa ti serve
Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
