Salta al contenuto principale
HP Chromebook 14-x013dx Speakers Replacement
Cosa ti serve
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: passo 1, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: passo 1, immagine 2 di 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: passo 2, immagine 1 di 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: passo 3, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement: passo 3, immagine 2 di 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: passo 4, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement: passo 4, immagine 2 di 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: passo 5, immagine 1 di 3 HP Chromebook 14-x013dx Speakers Replacement: passo 5, immagine 2 di 3 HP Chromebook 14-x013dx Speakers Replacement: passo 5, immagine 3 di 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: passo 6, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: passo 7, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement: passo 7, immagine 2 di 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: passo 8, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement: passo 8, immagine 2 di 2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: passo 9, immagine 1 di 1
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: passo 10, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement, Speakers: passo 10, immagine 2 di 2
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: passo 11, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement: passo 11, immagine 2 di 2
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: passo 12, immagine 1 di 2 HP Chromebook 14-x013dx Speakers Replacement: passo 12, immagine 2 di 2
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
Conclusione
NHerbert
Membro da: 09/28/17
602 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G6, Nance Fall 2017 Membro di USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 241
