Salta al contenuto principale
HP Chromebook 14-x013dx Screen Replacement
Cosa ti serve
  1. HP Chromebook 14-x013dx Screen Replacement, Screen: passo 1, immagine 1 di 3 HP Chromebook 14-x013dx Screen Replacement, Screen: passo 1, immagine 2 di 3 HP Chromebook 14-x013dx Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove lower left and right nylon flaps on the screen to remove the screws located underneath them.
    • The nylon strips on the side may be difficult to remove, as they are held on with adhesive. A spudger can be used to help remove these strips before removing with fingers.
    • Remove the two 2mm screws holding the bezel to the laptop case.
  2. HP Chromebook 14-x013dx Screen Replacement: passo 2, immagine 1 di 2 HP Chromebook 14-x013dx Screen Replacement: passo 2, immagine 2 di 2
    • Gently pry around the edges of the display using a spudger to remove the bezel that borders the screen.
  3. HP Chromebook 14-x013dx Screen Replacement: passo 3, immagine 1 di 2 HP Chromebook 14-x013dx Screen Replacement: passo 3, immagine 2 di 2
    • Remove glued plastic at the bottom of the cover.
  4. HP Chromebook 14-x013dx Screen Replacement: passo 4, immagine 1 di 1
    • Once glue is separated, pop out the front cover by pulling upwards on the hinge.
  5. HP Chromebook 14-x013dx Screen Replacement: passo 5, immagine 1 di 2 HP Chromebook 14-x013dx Screen Replacement: passo 5, immagine 2 di 2
    • Once the bezel has been removed, remove the four 5mm screws at the corners of the screen using a PH00 screwdriver.
  6. HP Chromebook 14-x013dx Screen Replacement: passo 6, immagine 1 di 3 HP Chromebook 14-x013dx Screen Replacement: passo 6, immagine 2 di 3 HP Chromebook 14-x013dx Screen Replacement: passo 6, immagine 3 di 3
    • Before completely removing the screen, detach the connected located at the bottom of the screen.
    • The connection to be removed should have a barcode marking.
Conclusione
Altre 3 persone hanno completato questa guida.
NHerbert
Membro da: 09/28/17
602 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G6, Nance Fall 2017 Membro di USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,793
