Introduzione
This guide will walk you through all the steps to remove the motherboard from your HP Chromebook 14-x010wm. You may find it reasonable to replace your motherboard if your CPU and/or I/O ports are damaged. This is a bit more challenging of a replacement process.
Be sure to take your time and not rush any steps.
Cosa ti serve
Start with unscrewing all 16 5.7mm screws from the bottom of the laptop.
Altre 3 persone hanno completato questa guida.
