Salta al contenuto principale
HP Chromebook 14-q010nr Keyboard Replacement
Cosa ti serve
  1. HP Chromebook 14-q010nr Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 HP Chromebook 14-q010nr Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 HP Chromebook 14-q010nr Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Use an opening pick to separate the keyboard from the chassis.
    • Lift the keyboard away, with care not to damage the connected ribbon cables.
  2. HP Chromebook 14-q010nr Keyboard Replacement: passo 2, immagine 1 di 2 HP Chromebook 14-q010nr Keyboard Replacement: passo 2, immagine 2 di 2
    • Flip up the black lock bars on the ZIF connectors, then remove the ribbon cables.
  3. HP Chromebook 14-q010nr Keyboard Replacement: passo 3, immagine 1 di 1
    • Gently raise the keyboard from the device and separate the two components.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 99
