Salta al contenuto principale
HP Chromebook 14-ca061dx Display Replacement
Cosa ti serve
  1. HP Chromebook 14-ca061dx Display Replacement, Display: passo 1, immagine 1 di 3 HP Chromebook 14-ca061dx Display Replacement, Display: passo 1, immagine 2 di 3 HP Chromebook 14-ca061dx Display Replacement, Display: passo 1, immagine 3 di 3
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: passo 2, immagine 1 di 1
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: passo 3, immagine 1 di 1
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: passo 4, immagine 1 di 2 HP Chromebook 14-ca061dx Display Replacement: passo 4, immagine 2 di 2
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: passo 5, immagine 1 di 2 HP Chromebook 14-ca061dx Display Replacement: passo 5, immagine 2 di 2
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: passo 6, immagine 1 di 2 HP Chromebook 14-ca061dx Display Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tapeā€”the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: passo 7, immagine 1 di 1
    • Remove the LCD/display panel from the Chromebook frame.
Conclusione
Jean Arevalo
Membro da: 10/31/19
778 Reputazione
6 Guide realizzate
Un commento
should disconnect the laptop battery first
TJ Kleckner - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,614
