Salta al contenuto principale
HP Chromebook 14-ak041dx Keyboard Replacement
Cosa ti serve
  1. HP Chromebook 14-ak041dx Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Chromebook 14-ak041dx Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Keyboard Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-ak041dx Keyboard Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-ak041dx Keyboard Replacement: passo 2, immagine 3 di 3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Keyboard Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-ak041dx Keyboard Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-ak041dx Keyboard Replacement: passo 3, immagine 3 di 3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
Conclusione
To reassemble your device, simply follow the steps in reverse. Make sure you replace all screws that were originally removed. Then check that the keyboard is correctly snapped back in place.
Kristen Gismondi
Membro da: 11/12/14
82.017 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 377
