Salta al contenuto principale
HP Chromebook 14-ak041dx Heat Sink Replacement
Cosa ti serve
  1. HP Chromebook 14-ak041dx Heat Sink Replacement, Keyboard: passo 1, immagine 1 di 2 HP Chromebook 14-ak041dx Heat Sink Replacement, Keyboard: passo 1, immagine 2 di 2
    • You will need a pair of tweezers and a Phillips screwdriver.
    • Remove eight 5mm Phillips #0 screws from the back cover of the laptop.
  2. HP Chromebook 14-ak041dx Heat Sink Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement: passo 2, immagine 3 di 3
    • Using a pair of tweezers, remove the five grey silicone covers.
    • Remove the five 5mm Phillips #0 screws beneath the grey silicone covers.
    • Place them aside where they will not be lost.
  3. HP Chromebook 14-ak041dx Heat Sink Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement: passo 3, immagine 3 di 3
    • Carefully open your Chromebook case and gently pull the keyboard away from the back panel.
    • Place the keyboard aside. Inspect for any visual damage or marks.
  4. HP Chromebook 14-ak041dx Heat Sink Replacement, Battery: passo 4, immagine 1 di 2 HP Chromebook 14-ak041dx Heat Sink Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the four 3mm Phillips #000 screws holding the battery in place.
  5. HP Chromebook 14-ak041dx Heat Sink Replacement: passo 5, immagine 1 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement: passo 5, immagine 2 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement: passo 5, immagine 3 di 3
    • Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
    • Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
  6. HP Chromebook 14-ak041dx Heat Sink Replacement: passo 6, immagine 1 di 1
    • Carefully lift the battery out of the laptop.
  7. HP Chromebook 14-ak041dx Heat Sink Replacement, Heat Sink: passo 7, immagine 1 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement, Heat Sink: passo 7, immagine 2 di 3 HP Chromebook 14-ak041dx Heat Sink Replacement, Heat Sink: passo 7, immagine 3 di 3
    • Remove the two 1.5mm Phillips #000 from the copper heat sink on top of the motherboard.
    • Remove the heat sink from the laptop.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
82.014 Reputazione
200 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 154
