Introduzione
This guide will walk you through the replacement of a dead or dying battery in your HP Chromebook 14-ak041dx. This replacement is a common need in the HP Chromebook 14-ak041dx, the computer will often not charge or hold a charge when plugged in and is in need of a replacement battery.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Slide a spudger underneath the white strip over the battery to gently pull the strip away from the adhesive sticking to the battery.
Using a pair of tweezers, grip the black tape connected to the battery, and gently pull back to unplug the battery.
