Salta al contenuto principale
HP Chromebook 14-ak013dx Internal Speaker Replacement
Cosa ti serve
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: passo 1, immagine 1 di 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: passo 1, immagine 2 di 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: passo 1, immagine 3 di 3
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: passo 2, immagine 1 di 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: passo 2, immagine 2 di 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: passo 2, immagine 3 di 3
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: passo 3, immagine 1 di 1
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: passo 4, immagine 1 di 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: passo 4, immagine 2 di 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: passo 4, immagine 3 di 3
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: passo 5, immagine 1 di 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: passo 5, immagine 2 di 2
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: passo 6, immagine 1 di 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: passo 6, immagine 2 di 2
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
Conclusione
dwsad Membro di dwsad
Community
1 Membro
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 87
