Introduzione
Before attempting this guide, you should have completed the prerequisite guides in order to gain access to the SSD. Use this guide to replace the SSD in your device.
Cosa ti serve
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
Carefully remove the (3) three plastic strips attached to the motherboard.
Remove screw using a phillips head screw driver.
I am stuck here. I’ve tried everything I know to get that screw off and it won’t budge. I am beginning to wonder if it is soldered, or glued, or corroded in place. Any suggestions?
Altre 3 persone hanno completato questa guida.
There are threaded nuts underneath the two screw holes located in the center of the computer (white caps cover them). When I removed the screws, the two nuts became loose and I found them in the pan after I took the battery out. I could not reattach these screws upon reassembly because there were no threads they could screw into, so I ended up with two screws and two nuts left over after completion. Are you sure it is really necessary to remove these two center screws?
Thomas Badura - Replica
