Introduzione
A motherboard is essentially the brain of a computer, it controls all the components in a computer to function properly without any errors. Use this guide to replace the motherboard of your device.
Cosa ti serve
Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
Carefully remove the (3) three plastic strips attached to the motherboard.
