Salta al contenuto principale
HP Chromebook 14-Q070NR Motherboard Replacement
Cosa ti serve
  1. HP Chromebook 14-Q070NR Motherboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Motherboard Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-Q070NR Motherboard Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-Q070NR Motherboard Replacement: passo 2, immagine 3 di 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Motherboard Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-Q070NR Motherboard Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-Q070NR Motherboard Replacement: passo 3, immagine 3 di 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Motherboard Replacement: passo 4, immagine 1 di 3 HP Chromebook 14-Q070NR Motherboard Replacement: passo 4, immagine 2 di 3 HP Chromebook 14-Q070NR Motherboard Replacement: passo 4, immagine 3 di 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Motherboard Replacement, Battery: passo 5, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Motherboard Replacement: passo 6, immagine 1 di 2 HP Chromebook 14-Q070NR Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Motherboard Replacement: passo 7, immagine 1 di 1
    • Carefully lift the battery and remove it from the device.
  8. HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: passo 8, immagine 1 di 3 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: passo 8, immagine 2 di 3 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: passo 8, immagine 3 di 3
    • Carefully remove the (3) three plastic strips attached to the motherboard.
  9. HP Chromebook 14-Q070NR Motherboard Replacement: passo 9, immagine 1 di 2 HP Chromebook 14-Q070NR Motherboard Replacement: passo 9, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the (5) five screws.
  10. HP Chromebook 14-Q070NR Motherboard Replacement: passo 10, immagine 1 di 2 HP Chromebook 14-Q070NR Motherboard Replacement: passo 10, immagine 2 di 2
    • Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
  11. HP Chromebook 14-Q070NR Motherboard Replacement: passo 11, immagine 1 di 2 HP Chromebook 14-Q070NR Motherboard Replacement: passo 11, immagine 2 di 2
    • Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern.
    • Be very careful not to detach the motherboard to quickly or forcefully since you could damage or break it.
Conclusione
Jose Hernandez
Membro da: 10/02/17
101 Reputazione
1 Guida realizzata
USF Tampa, Team S9-G5, Remmell Fall 2017 Membro di USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 274
