Salta al contenuto principale
HP Chromebook 14-Q070NR Keyboard Replacement
Cosa ti serve
  1. HP Chromebook 14-Q070NR Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Keyboard Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-Q070NR Keyboard Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-Q070NR Keyboard Replacement: passo 2, immagine 3 di 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Keyboard Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-Q070NR Keyboard Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-Q070NR Keyboard Replacement: passo 3, immagine 3 di 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Keyboard Replacement: passo 4, immagine 1 di 3 HP Chromebook 14-Q070NR Keyboard Replacement: passo 4, immagine 2 di 3 HP Chromebook 14-Q070NR Keyboard Replacement: passo 4, immagine 3 di 3
    • Once the ribbons are detached, remove the keyboard from the device.
Conclusione
USF Tampa, Team S9-G5, Remmell Fall 2017 Membro di USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 313
