Salta al contenuto principale
HP Chromebook 14-Q070NR Display Replacement
Cosa ti serve
  1. HP Chromebook 14-Q070NR Display Replacement, Keyboard: passo 1, immagine 1 di 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Display Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 2, immagine 3 di 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Display Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 3, immagine 3 di 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Display Replacement: passo 4, immagine 1 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 4, immagine 2 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 4, immagine 3 di 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Display Replacement, Display: passo 5, immagine 1 di 1
    • Unplug the cable located in the upper left corner of the device.
  6. HP Chromebook 14-Q070NR Display Replacement: passo 6, immagine 1 di 1
    • Remove these tabs located at each of the bottom corners of the display.
    • It is not necessary for the display to be completely removed from the device in order to complete this guide.
    • Using the Phillips #1 screwdriver, remove the single screw located under each of the two tabs.
  7. HP Chromebook 14-Q070NR Display Replacement: passo 7, immagine 1 di 1
    • Insert the plastic opening tool and work it around the entire frame of the display.
  8. HP Chromebook 14-Q070NR Display Replacement: passo 8, immagine 1 di 2 HP Chromebook 14-Q070NR Display Replacement: passo 8, immagine 2 di 2
    • As you work the plastic opening tool around the edge, remove the front frame of the device.
  9. HP Chromebook 14-Q070NR Display Replacement: passo 9, immagine 1 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 9, immagine 2 di 3 HP Chromebook 14-Q070NR Display Replacement: passo 9, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove the (4) four screws located at the bottom of the display.
    • Once the screws are removed, lift the display out of the device.
Conclusione
USF Tampa, Team S9-G5, Remmell Fall 2017 Membro di USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Membri
5 Guide realizzate
Un commento
This was very helpful, I broke the screen to my chromebook whilst shutting the lid and the screen cracked. I didn’t want to spend the money on a new screen so I decided to take the whole top half off the chomebook and basically make a chromebox.
quardpd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 286
