Introduzione
This guide will require removal of 1x3mm screws.
Cosa ti serve
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Using a spudger, remove the white and black cables from the card.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
Remove all of the indicated screws.
Pull up on black strip to remove the monitor cord.
Altre 13 persone hanno completato questa guida.
3 Commenti
Thanks so much for your clearly , detailed and easy to follow guide, nice job!
Can you add more storage on the HP Chromebook 14 SMB about 500GB. I also want to know if the Chromebook can run Windows 10 without any problems.
