Salta al contenuto principale
HP Chromebook 14-Q010DX Hard drive Replacement
Cosa ti serve
  1. HP Chromebook 14-Q010DX Hard drive Replacement, Keyboard and Touchpad: passo 1, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement, Keyboard and Touchpad: passo 1, immagine 2 di 2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Hard drive Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 2, immagine 3 di 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Hard drive Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 3, immagine 3 di 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Hard drive Replacement: passo 4, immagine 1 di 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Hard drive Replacement: passo 5, immagine 1 di 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Hard drive Replacement, Speaker: passo 6, immagine 1 di 3 HP Chromebook 14-Q010DX Hard drive Replacement, Speaker: passo 6, immagine 2 di 3 HP Chromebook 14-Q010DX Hard drive Replacement, Speaker: passo 6, immagine 3 di 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
  7. HP Chromebook 14-Q010DX Hard drive Replacement: passo 7, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement: passo 7, immagine 2 di 2
    • Gently remove the speakers.
  8. HP Chromebook 14-Q010DX Hard drive Replacement, Battery: passo 8, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement, Battery: passo 8, immagine 2 di 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
  9. HP Chromebook 14-Q010DX Hard drive Replacement: passo 9, immagine 1 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 9, immagine 2 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 9, immagine 3 di 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    While reassembling, the chromebook powered up when I reconnected the battery. Didn’t know how I could power it down, as the keyboard was not connected at this point.
    Bart - Replica
  10. HP Chromebook 14-Q010DX Hard drive Replacement: passo 10, immagine 1 di 1
    • Gently remove battery.
  11. HP Chromebook 14-Q010DX Hard drive Replacement, Bluetooth and Wireless Card: passo 11, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement, Bluetooth and Wireless Card: passo 11, immagine 2 di 2
    • Using a spudger, remove the white and black cables from the card.
  12. HP Chromebook 14-Q010DX Hard drive Replacement: passo 12, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement: passo 12, immagine 2 di 2
    • Remove screw from card.
  13. HP Chromebook 14-Q010DX Hard drive Replacement: passo 13, immagine 1 di 1
    • Gently pull card at a 45° angle to remove it.
  14. HP Chromebook 14-Q010DX Hard drive Replacement, USB/SD card: passo 14, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement, USB/SD card: passo 14, immagine 2 di 2
    • Remove screw indicated by the red circle at the top of the card port.
  15. HP Chromebook 14-Q010DX Hard drive Replacement: passo 15, immagine 1 di 1
    • Gently remove the USB/SD card port.
  16. HP Chromebook 14-Q010DX Hard drive Replacement, Fan: passo 16, immagine 1 di 3 HP Chromebook 14-Q010DX Hard drive Replacement, Fan: passo 16, immagine 2 di 3 HP Chromebook 14-Q010DX Hard drive Replacement, Fan: passo 16, immagine 3 di 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
  17. HP Chromebook 14-Q010DX Hard drive Replacement: passo 17, immagine 1 di 1
    • Gently remove fan.
    how do I go about taking the fan off and what do I do after that?
    Maddie - Replica
    Do I need to replace my fan?
    Maddie - Replica
  18. HP Chromebook 14-Q010DX Hard drive Replacement, Motherboard: passo 18, immagine 1 di 2 HP Chromebook 14-Q010DX Hard drive Replacement, Motherboard: passo 18, immagine 2 di 2
    • Using your fingers or spudger, pull out the connector.
  19. HP Chromebook 14-Q010DX Hard drive Replacement: passo 19, immagine 1 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 19, immagine 2 di 3 HP Chromebook 14-Q010DX Hard drive Replacement: passo 19, immagine 3 di 3
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
    The pic with the 3 screws circled in red is missing
    Paula Hague - Replica
  20. HP Chromebook 14-Q010DX Hard drive Replacement: passo 20, immagine 1 di 1
    • Gently remove motherboard.
  21. HP Chromebook 14-Q010DX Hard drive Replacement, Hard drive: passo 21, immagine 1 di 1
    • Flip motherboard over.
  22. HP Chromebook 14-Q010DX Hard drive Replacement: passo 22, immagine 1 di 1
    • Remove the screw indicated by the red circle.
  23. HP Chromebook 14-Q010DX Hard drive Replacement: passo 23, immagine 1 di 1
    • Remove the hard drive by pulling the device from the black slot.
Conclusione
Altre 13 persone hanno completato questa guida.
Kevin Piper
Membro da: 01/16/15
1.587 Reputazione
6 Guide realizzate
USF Tampa, Team 17-2, Watkins Winter 2015 Membro di USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Membri
8 Guide realizzate
3 Commenti
Thanks so much for your clearly , detailed and easy to follow guide, nice job!
pedro munoz - Replica
Buenas tarde y despuesnde quitar el disco duro que se hace se cambia por otro igual o que modelo
chaffa_45 - Replica
Can you add more storage on the HP Chromebook 14 SMB about 500GB. I also want to know if the Chromebook can run Windows 10 without any problems.
Fire Alarm Collector - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 96
Tutti i Tempi: 20,532
