Salta al contenuto principale
HP Chromebook 14 G5 Wi-Fi Card Replacement
Cosa ti serve
  1. HP Chromebook 14 G5 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 2 di 2
    • Use a spudger to remove four rubber feet from the corners of the laptop.
    • Use a spudger to remove seven silicone covers.
  2. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 2, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Remove the 11 screws from the bottom panel using a Phillips #1 screwdriver.
  3. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 3, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Flip the laptop over and open up the display.
    • Using a opening pick, carefully separate the top housing from the bottom housing by working your way around the perimeter of the laptop and prying it open.
  4. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 4, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 4, immagine 2 di 2
    • Peel back the black tape covering the battery connector.
    • Using the spudger, unplug the battery connector from the motherboard.
  5. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 5, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Carefully lift the keyboard ribbon lock with the spudger and disconnect the keyboard ribbon cable from the motherboard.
  6. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 6, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 6, immagine 2 di 2
    • Carefully lift the touch pad ribbon lock with the spudger and disconnect the touch pad ribbon cable from the motherboard.
    • Remove the keyboard assembly from the device housing.
  7. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 7, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 7, immagine 2 di 2
    • Using the spudger, disconnect the two antennas from the Wi-Fi card.
  8. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #0 screwdriver, remove the screw securing the Wi-Fi card.
  9. HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 9, immagine 1 di 2 HP Chromebook 14 G5 Wi-Fi Card Replacement: passo 9, immagine 2 di 2
    • Gently remove the Wi-Fi card.
Conclusione
Ethan Tran
Membro da: 10/24/23
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 78
