Salta al contenuto principale
HP Chromebook 14 G5 SD card reader Replacement
Cosa ti serve
  1. HP Chromebook 14 G5 SD card reader Replacement, SD card reader: passo 1, immagine 1 di 1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 SD card reader Replacement: passo 2, immagine 1 di 1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 SD card reader Replacement: passo 3, immagine 1 di 1
    • Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
  4. HP Chromebook 14 G5 SD card reader Replacement: passo 4, immagine 1 di 1
    • Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
  5. HP Chromebook 14 G5 SD card reader Replacement: passo 5, immagine 1 di 2 HP Chromebook 14 G5 SD card reader Replacement: passo 5, immagine 2 di 2
    • Disconnect the Flexible Flat Cable (FFC) from the motherboard.
  6. HP Chromebook 14 G5 SD card reader Replacement: passo 6, immagine 1 di 1
    • Remove the SD card reader the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 324
