Salta al contenuto principale
HP Chromebook 14 G5 Motherboard Replacement
Cosa ti serve
  1. HP Chromebook 14 G5 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 Motherboard Replacement: passo 2, immagine 1 di 1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 Motherboard Replacement: passo 3, immagine 1 di 2 HP Chromebook 14 G5 Motherboard Replacement: passo 3, immagine 2 di 2
    • Then you can see the motherboard marked in the yellow rectangle.
    • Unscrew the 4.1mm screws around the motherboard using the Phillips #00 screwdriver.
  4. HP Chromebook 14 G5 Motherboard Replacement: passo 4, immagine 1 di 2 HP Chromebook 14 G5 Motherboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the two Flexible Flat Cable (FFC) from the device.
  5. HP Chromebook 14 G5 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the motherboard from the device.
Conclusione
We omitted some photos of reassembling the device. For this part, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,223
