Introduzione
To see how to replace your heatsink as well as your thermal paste, follow this guide. You will need an IFixit opening pick, a #0 Phillips screwdriver, a #000 Phillips screwdriver, a metal spudger, and tweezers with round and pointed tips.
Cosa ti serve
Position the Chromebook with the bottom facing up.
Locate the 8 screws on the back of the Chromebook.
Next, remove the 8 (8mm) screws using the phillips screw driver with the #0 bit.
Gentally lift up the keyboard and locate the two ribbons attatched to the motherboard.
Use the IFixit Opening Tool to lift the two tabs located on the zero insertion force (ZIF) connectors.
To do this, use the tip of the IFixit Opening Tool to flip up the small locking flap and gently pull the ribbon out.
Then, fully remove the keyboard and set aside.
Locate the bundled cable connector connecting the battery to the motherboard.
Use the precision tweezers to peel back the black tape covering the bundled cable connector.
Next, use the precision tweezers to grab the edge of the connector and slowly pull the cable towards you.
Locate the bundled cable connector connecting the speakers to the motherboard.
Using the precision tweezers, peel back the plastic that is covering the bundled cable connector.
Then, use the precision tweezers to grab the edges of the bundled cable connector and remove by pulling towards the battery.
Locate the ribbons and their ZIF connectors connecting the motherboard and the daughterboard.
Use the precision tweezers to peel back the plastic and uncover the ZIF connectors located at the end of each ribbon.
Use the IFixit Opening Tool to flip up the locking flap holding the ribons in place.
Then, gently pull out each ribon.
On the top left corner of the motherboard, gently unplug the bundled cable from the motherboard.
Once you have pulled your motherboard out from your laptop, flip the motherboard over and locate the two 2mm screws in the heatsink.
Using a #000 Phillips screwdriver, remove the screws from the heatsink.
