Salta al contenuto principale
HP Chromebook 11A G8 EE Keyboard Assembly Replacement
Cosa ti serve
  1. HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: passo 1, immagine 1 di 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: passo 1, immagine 2 di 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 2, immagine 1 di 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 2, immagine 2 di 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 2, immagine 3 di 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 3, immagine 1 di 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: passo 3, immagine 2 di 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
Conclusione
Altre 6 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,707
