Salta al contenuto principale
HP Chromebook 11-v011dx Key Board Replacement
Cosa ti serve
  1. HP Chromebook 11-v011dx Key Board  Replacement, Key Board: passo 1, immagine 1 di 3 HP Chromebook 11-v011dx Key Board  Replacement, Key Board: passo 1, immagine 2 di 3 HP Chromebook 11-v011dx Key Board  Replacement, Key Board: passo 1, immagine 3 di 3
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
  2. HP Chromebook 11-v011dx Key Board  Replacement: passo 2, immagine 1 di 2 HP Chromebook 11-v011dx Key Board  Replacement: passo 2, immagine 2 di 2
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
  3. HP Chromebook 11-v011dx Key Board  Replacement: passo 3, immagine 1 di 2 HP Chromebook 11-v011dx Key Board  Replacement: passo 3, immagine 2 di 2
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
  4. HP Chromebook 11-v011dx Key Board  Replacement: passo 4, immagine 1 di 3 HP Chromebook 11-v011dx Key Board  Replacement: passo 4, immagine 2 di 3 HP Chromebook 11-v011dx Key Board  Replacement: passo 4, immagine 3 di 3
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
  5. HP Chromebook 11-v011dx Key Board  Replacement: passo 5, immagine 1 di 1
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
Conclusione
Kyle DeMello
Membro da: 10/20/17
542 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 273
