Introduzione
This guide will walk you through easy steps in order to change the motherboard for your HP Chromebook 11-v002dx.
You may want to try cleaning the area underneath your motherboard and the points where it connects to your laptop before replacing your board entirely, as dust can occasionally accumulate and prevent it from functioning.
Cosa ti serve
Place your laptop bottom up on your work space.
Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
Pinch the thin black bar which holds the right side of the black ribbon down, and flip it up.
Gently pull the ribbon out of the black holder on its right, then out of the left side as well.
