Salta al contenuto principale
HP Chromebook 11-v002dx Battery Replacement
Cosa ti serve
  1. HP Chromebook 11-v002dx Battery Replacement, Keyboard: passo 1, immagine 1 di 2 HP Chromebook 11-v002dx Battery Replacement, Keyboard: passo 1, immagine 2 di 2
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Battery Replacement: passo 2, immagine 1 di 3 HP Chromebook 11-v002dx Battery Replacement: passo 2, immagine 2 di 3 HP Chromebook 11-v002dx Battery Replacement: passo 2, immagine 3 di 3
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Battery Replacement: passo 3, immagine 1 di 2 HP Chromebook 11-v002dx Battery Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Battery Replacement: passo 4, immagine 1 di 2 HP Chromebook 11-v002dx Battery Replacement: passo 4, immagine 2 di 2
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
  5. HP Chromebook 11-v002dx Battery Replacement, Battery: passo 5, immagine 1 di 2 HP Chromebook 11-v002dx Battery Replacement, Battery: passo 5, immagine 2 di 2
    • Flip up the black tab on the far right of the wire ribbon.
    • Gently pull the wire out of the black holder on its right, then out of the left side as well.
  6. HP Chromebook 11-v002dx Battery Replacement: passo 6, immagine 1 di 3 HP Chromebook 11-v002dx Battery Replacement: passo 6, immagine 2 di 3 HP Chromebook 11-v002dx Battery Replacement: passo 6, immagine 3 di 3
    • Using your Phillips #0 screwdriver, remove the five 0.2 mm screws from the battery.
  7. HP Chromebook 11-v002dx Battery Replacement: passo 7, immagine 1 di 3 HP Chromebook 11-v002dx Battery Replacement: passo 7, immagine 2 di 3 HP Chromebook 11-v002dx Battery Replacement: passo 7, immagine 3 di 3
    • Pinch the edges of the white tab with the wires coming out of the end.
    • Gently remove the white tab with the wires from its holder on the motherboard.
  8. HP Chromebook 11-v002dx Battery Replacement: passo 8, immagine 1 di 2 HP Chromebook 11-v002dx Battery Replacement: passo 8, immagine 2 di 2
    • Gently remove the battery from the laptop completely.
    • You can either clean your battery and connection ports or completely replace it.
Conclusione
Altre 2 persone hanno completato questa guida.
Abby Zilvitis
Membro da: 04/17/17
448 Reputazione
4 Guide realizzate
Cal Poly, Team S14-G1, Banghart Spring 2017 Membro di Cal Poly, Team S14-G1, Banghart Spring 2017
CPSU-BANGHART-S17S14G1
4 Membri
5 Guide realizzate
Un commento
Insructions exerlent . What price battary
Yorky Jaggs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,396
