Salta al contenuto principale
HP Chromebook 11-2210nr LCD Screen Replacement
Cosa ti serve
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: passo 3, immagine 1 di 2 HP Chromebook 11-2210nr LCD Screen Replacement: passo 3, immagine 2 di 2
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: passo 4, immagine 1 di 2 HP Chromebook 11-2210nr LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: passo 5, immagine 1 di 1
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: passo 6, immagine 1 di 2 HP Chromebook 11-2210nr LCD Screen Replacement: passo 6, immagine 2 di 2
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: passo 7, immagine 1 di 2 HP Chromebook 11-2210nr LCD Screen Replacement: passo 7, immagine 2 di 2
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 433
