Salta al contenuto principale
HP Chromebook 11 G8 EE Wi-Fi Card Replacement
Cosa ti serve
  1. HP Chromebook 11 G8 EE Wi-Fi Card Replacement, Keyboard & Touchpad Assembly: passo 1, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 2, immagine 1 di 2 HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 3, immagine 1 di 3 HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 3, immagine 2 di 3 HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 1
    Compra
    • Use tweezers to unplug the battery connector from the motherboard.
  5. HP Chromebook 11 G8 EE Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Peel back clear sheet covering Wi-Fi card.
    • Unscrew the single screw securing Wi-Fi card/cover using a Phillips #1 screwdriver.
    • Carefully slide the Wi-Fi card out.
Conclusione
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro di UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 43
Tutti i Tempi: 537
