Salta al contenuto principale
HP Chromebook 11 G8 EE Speaker Replacement
Cosa ti serve
  1. HP Chromebook 11 G8 EE Speaker Replacement, Keyboard & Touchpad Assembly: passo 1, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Speaker Replacement: passo 2, immagine 1 di 2 HP Chromebook 11 G8 EE Speaker Replacement: passo 2, immagine 2 di 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Speaker Replacement: passo 3, immagine 1 di 3 HP Chromebook 11 G8 EE Speaker Replacement: passo 3, immagine 2 di 3 HP Chromebook 11 G8 EE Speaker Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Speaker Replacement, Speaker: passo 4, immagine 1 di 2 HP Chromebook 11 G8 EE Speaker Replacement, Speaker: passo 4, immagine 2 di 2
    • Peel back the film over the speaker's motherboard connector.
    • Disconnect the speaker cable from the connector on the motherboard.
  5. HP Chromebook 11 G8 EE Speaker Replacement: passo 5, immagine 1 di 2 HP Chromebook 11 G8 EE Speaker Replacement: passo 5, immagine 2 di 2
    • Unseat the speaker cable from the routing channel of the battery.
  6. HP Chromebook 11 G8 EE Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
  7. HP Chromebook 11 G8 EE Speaker Replacement: passo 7, immagine 1 di 3 HP Chromebook 11 G8 EE Speaker Replacement: passo 7, immagine 2 di 3 HP Chromebook 11 G8 EE Speaker Replacement: passo 7, immagine 3 di 3
    • Lift the speakers off the base alignment pins to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
Julia Latura
Membro da: 10/25/22
328 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membro di UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 183
