Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide walks through removing the upper case and keyboard mount. This guide requires a Phillips screwdriver, a plastic opening tool, a spudger, and tweezers.
  1. Flip the laptop upside down so that the lid lies flat on the table. Remove the nine 6mm Phillips #00 screws that line the border.
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. Remove the two rubber feet closest to the hinge using tweezers. Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  4. Flip the laptop so it is in the upright position.
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  5. Tilt the keyboard mount up. Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard. Gently remove both ribbon cables.
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  6. Lift the keyboard mount out of the laptop.
    • Lift the keyboard mount out of the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Rahul Goyal
Membro da: 26/04/2017
1.337 Reputazione
10 Guide realizzate
Cal Poly, Team S23-G3, Livingston Spring 2017 Membro di Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 169
