Introduzione
This guide walks through replacing a faulty charging port. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a plastic opening tool to finish removal.
Cosa ti serve
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Gently remove the charging port’s slide-out connector from the motherboard.
Un commento
I have a Model CB2 (also known as 11-1102) that has this same issue. Would the instructions be the same? Would the part be the same? Where did you purchase a replacement charging port?
