Introduzione
This guide walks through replacing a faulty charging port. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a plastic opening tool to finish removal.
Cosa ti serve
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Gently remove the charging port’s slide-out connector from the motherboard.
Un commento
I have a Model CB2 (also known as 11-1102) that has this same issue. Would the instructions be the same? Would the part be the same? Where did you purchase a replacement charging port?
