Introduzione
This guide walks through replacing a faulty battery. It requires removing the keyboard mount. Afterwards, it is relatively simple and requires only a Phillips head screwdriver to finish removal.
Cosa ti serve
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Gently remove the battery’s rainbow-colored bundled cable from the motherboard.
Altre 5 persone hanno completato questa guida.
Un commento
Can the HP Chromebook 11 G3 be operated from the power adapter after the battery has been removed?
