Salta al contenuto principale
HP Beats Special Edition 15-p390nr WiFi Card Replacement
Cosa ti serve
  1. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: passo 1, immagine 1 di 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement, Keyboard: passo 1, immagine 2 di 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 2, immagine 1 di 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 2, immagine 2 di 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 3, immagine 1 di 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 3, immagine 2 di 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 4, immagine 1 di 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 4, immagine 2 di 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 5, immagine 1 di 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 5, immagine 2 di 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 6, immagine 1 di 2 HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 6, immagine 2 di 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr WiFi Card  Replacement, WiFi Card: passo 7, immagine 1 di 1
    • Once the keyboard panel is removed you will need to locate the WiFi card
  8. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 8, immagine 1 di 1
    • Remove two screws using the Phillips #0 screwdriver.
  9. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 9, immagine 1 di 1
    • Remove wire connected to the back of the card by pulling it straight up.
  10. HP Beats Special Edition 15-p390nr WiFi Card  Replacement: passo 10, immagine 1 di 1
    • Pull card away from you to remove it from the motherboard.
    • Refrain from wiggling or moving the card around, while connected to the motherboard, to prevent damage to connector pins.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,123
