Salta al contenuto principale
HP Beats Special Edition 15-p390nr Motherboard Replacement
Cosa ti serve
  1. HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 2, immagine 1 di 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 2, immagine 2 di 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 3, immagine 1 di 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 3, immagine 2 di 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 4, immagine 1 di 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 5, immagine 1 di 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 5, immagine 2 di 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 6, immagine 1 di 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 6, immagine 2 di 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 8, immagine 1 di 1
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 9, immagine 1 di 1
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Motherboard Replacement: passo 10, immagine 1 di 1
    • Unclip wifi card for further procedures
Conclusione
4 Commenti
Please where can i buy the motherboard ?
Nelson - Replica
Please, where can i buy a new motherboard for this laptop ? Thank you
Nelson - Replica
What does it mean if it beeps twice and doesn’t turn on? I replaced the cmos battery and thought that would fix that beeping sound.
Landon Elliott - Replica
You may want yo start with reseating your ram or replacing it
Juan Lopez -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,619
