Introduzione
This guide is useful if you need to replace any of the parts inside the device. When moving the opening tool around the device, it might be necessary to pull a little to detach the two sides.
Cosa ti serve
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
To reassemble your device, follow these instructions in reverse order. Align the front and back panels and press them together, then screw in the four screws.
