Salta al contenuto principale
HP 7 Plus 1302 Power and Volume Button Replacement
Cosa ti serve
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: passo 2, immagine 1 di 2 HP 7 Plus 1302 Power and Volume Button Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: passo 3, immagine 1 di 2 HP 7 Plus 1302 Power and Volume Button Replacement: passo 3, immagine 2 di 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: passo 4, immagine 1 di 1
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: passo 5, immagine 1 di 2 HP 7 Plus 1302 Power and Volume Button Replacement: passo 5, immagine 2 di 2
    • Pop out the power and volume buttons with your hands
Conclusione
IUPUI, Team 1-4, Baechle Spring 2017 Membro di IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 254
