Salta al contenuto principale
HP 7 Plus 1302 Charging Port Replacement
Cosa ti serve
  1. HP 7 Plus 1302 Charging Port Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Charging Port Replacement: passo 2, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Charging Port Replacement: passo 3, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 3, immagine 2 di 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Charging Port Replacement, Battery: passo 4, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement, Battery: passo 4, immagine 2 di 2
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Charging Port Replacement: passo 5, immagine 1 di 1
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Charging Port Replacement, Motherboard: passo 6, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement, Motherboard: passo 6, immagine 2 di 2
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Charging Port Replacement: passo 7, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 7, immagine 2 di 2
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Charging Port Replacement: passo 8, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 8, immagine 2 di 2
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Charging Port Replacement: passo 9, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 9, immagine 2 di 2
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Charging Port Replacement: passo 10, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 10, immagine 2 di 2
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Charging Port Replacement: passo 11, immagine 1 di 3 HP 7 Plus 1302 Charging Port Replacement: passo 11, immagine 2 di 3 HP 7 Plus 1302 Charging Port Replacement: passo 11, immagine 3 di 3
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Charging Port Replacement: passo 12, immagine 1 di 1
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Charging Port Replacement: passo 13, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 13, immagine 2 di 2
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Charging Port Replacement: passo 14, immagine 1 di 2 HP 7 Plus 1302 Charging Port Replacement: passo 14, immagine 2 di 2
    • Pull the circuit board off.
  15. HP 7 Plus 1302 Charging Port Replacement, Charging Port: passo 15, immagine 1 di 1
    • Desolder the four points on the charging port using the soldering iron.
    • Soldering iron will be hot be careful.
    • For more instructions about how to use the Soldering iron click here.
Conclusione
IUPUI, Team 1-4, Baechle Spring 2017 Membro di IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 431
