Salta al contenuto principale
HP 7 Plus 1302 Back Cover Replacement
Cosa ti serve
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: passo 2, immagine 1 di 2 HP 7 Plus 1302 Back Cover Replacement: passo 2, immagine 2 di 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: passo 3, immagine 1 di 2 HP 7 Plus 1302 Back Cover Replacement: passo 3, immagine 2 di 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
Conclusione
Marquies
Membro da: 07/07/15
245 Reputazione
1 Guida realizzata
IUPUI, Team 1-2, Renguette SU 2015 Membro di IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,020
