Salta al contenuto principale
HP 7 PLUS 1301 Front and Back Camera Replacement
Cosa ti serve
  1. HP 7 PLUS 1301 Front and Back Camera Replacement, Front and Back Camera: passo 1, immagine 1 di 2 HP 7 PLUS 1301 Front and Back Camera Replacement, Front and Back Camera: passo 1, immagine 2 di 2
    • Make sure the device is off and not plugged in before starting.
    • Using a Torx T5 screwdriver, remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Front and Back Camera Replacement: passo 2, immagine 1 di 2 HP 7 PLUS 1301 Front and Back Camera Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Front and Back Camera Replacement: passo 3, immagine 1 di 2 HP 7 PLUS 1301 Front and Back Camera Replacement: passo 3, immagine 2 di 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Front and Back Camera Replacement: passo 4, immagine 1 di 1
    • Locate the front and rear cameras.
  5. HP 7 PLUS 1301 Front and Back Camera Replacement: passo 5, immagine 1 di 2 HP 7 PLUS 1301 Front and Back Camera Replacement: passo 5, immagine 2 di 2
    • Using the opening tool, locate the rectangular gray connector near the camera and gently release its connection.
    • Lift the connector out and away from the board.
    • This will come out very easily so don't use much force.
  6. HP 7 PLUS 1301 Front and Back Camera Replacement: passo 6, immagine 1 di 2 HP 7 PLUS 1301 Front and Back Camera Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Gently push the tabs on both sides until the front camera is loose.
    • Using your blunt tweezers, lift the front camera gently away from the board.
  7. HP 7 PLUS 1301 Front and Back Camera Replacement: passo 7, immagine 1 di 3 HP 7 PLUS 1301 Front and Back Camera Replacement: passo 7, immagine 2 di 3 HP 7 PLUS 1301 Front and Back Camera Replacement: passo 7, immagine 3 di 3
    • Using your angled tweezers, gently pry out the back camera.
    • The camera is held down with tape.
    • Lift the back camera out of its socket and gently pull out both cameras.
Conclusione
ahmed musleh
Membro da: 02/05/19
195 Reputazione
1 Guida realizzata
UC Davis, Team S20-G6, Lore Winter 2019 Membro di UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 148
