Introduzione
The battery might need to be changed if the device does not power up, or does not charge anymore. The most challenging step to changing the battery is removing the back cover. The tools listed (or similar) are necessary for the battery replacement.
Cosa ti serve
Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
