Salta al contenuto principale
HP 7 PLUS 1301 Battery Replacement
Cosa ti serve
  1. HP 7 PLUS 1301 Battery Replacement, Battery: passo 1, immagine 1 di 2 HP 7 PLUS 1301 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: passo 2, immagine 1 di 2 HP 7 PLUS 1301 Battery Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: passo 3, immagine 1 di 2 HP 7 PLUS 1301 Battery Replacement: passo 3, immagine 2 di 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: passo 4, immagine 1 di 2 HP 7 PLUS 1301 Battery Replacement: passo 4, immagine 2 di 2
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: passo 5, immagine 1 di 1
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
Conclusione
Adanna Ilori
Membro da: 02/05/19
301 Reputazione
2 Guide realizzate
UC Davis, Team S20-G6, Lore Winter 2019 Membro di UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 743
