Salta al contenuto principale
HP 7 1800 Front Facing Camera Replacement
Cosa ti serve
  1. HP 7 1800 Front Facing Camera Replacement, Remove the back panel: passo 1, immagine 1 di 2 HP 7 1800 Front Facing Camera Replacement, Remove the back panel: passo 1, immagine 2 di 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Front Facing Camera Replacement, Remove the battery: passo 2, immagine 1 di 3 HP 7 1800 Front Facing Camera Replacement, Remove the battery: passo 2, immagine 2 di 3 HP 7 1800 Front Facing Camera Replacement, Remove the battery: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: passo 3, immagine 1 di 2 HP 7 1800 Front Facing Camera Replacement, Remove the large ribbon cable: passo 3, immagine 2 di 2
    Compra
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: passo 4, immagine 1 di 2 HP 7 1800 Front Facing Camera Replacement, Remove the smaller ribbon cable: passo 4, immagine 2 di 2
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 silver screws from the logic board: passo 5, immagine 1 di 1
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Front Facing Camera Replacement, Unplug the front facing camera from the logic board: passo 6, immagine 1 di 1
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Front Facing Camera Replacement, Remove the logic board: passo 7, immagine 1 di 1
    • Carefully lift the motherboard directly up.
  8. HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: passo 8, immagine 1 di 2 HP 7 1800 Front Facing Camera Replacement, Remove the ribbon cable attached to the metal plate: passo 8, immagine 2 di 2
    • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
  9. HP 7 1800 Front Facing Camera Replacement, Unscrew the 7 black screws on the metal plate: passo 9, immagine 1 di 1
    • Unscrew the following black screws:
    • Seven 2.82mm Phillips #00 around the metal casing.
  10. HP 7 1800 Front Facing Camera Replacement, Remove the metal plate: passo 10, immagine 1 di 1
    • Gently lift the metal plate directly up.
  11. HP 7 1800 Front Facing Camera Replacement, Remove the camera: passo 11, immagine 1 di 1
    Compra
    • Gently remove the camera from the device with tweezers by lifting it up and out of its square hole.
Conclusione
Trevor Shumate
Membro da: 01/21/15
225 Reputazione
2 Guide realizzate
USF Tampa, Team 4-1, Brown Winter 2015 Membro di USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 247
